Dude, does it fit our cars?
I don't know! Someone find out will ya, call a dealer or something. The 2-way fobs never really interested me but after reading more on them I found out one remote can be used for two vehicles! Now I'm interested!Dude, does it fit our cars?
Well that sucks, maybe your problem is the placement of the extended range antenna thingamager.......Its not the first time I have heard of that issue.I got the two way remote system put in my car. I did not have remote start before. I am very disapointed with it. I t will not work unless you have a clear view of the car and are very close. I cann't even start the car from in the house without pointing it out of the window. I payed close to $400 for the system and could have got a really good aftermarket one. I live it Alberta and it is -30C some times and 15min run time is not enough run time. To have to go into thed car and cycle the ign. before it will work again is just STUPID, might as well start the damn thing with the key. I kind of walked into this with a blind eye as I did not research it that much and just wanted something that was compadable with my car and didn't have to be wired in..
Trevor
Yeah, something isn't right. As I said earlier I have just the regular remote start and I can start my car from my 2nd story office, though a couple of walls from 100+ft away. I just reach into my coat pocket, press lock and then hold start and it starts every time. I'm not even within a line of sight of my vehicle.Well that sucks, maybe your problem is the placement of the extended range antenna thingamager.......Its not the first time I have heard of that issue.
Good for you, it is an nice feature to have. My Malibu was already equipped with it but my Silverado was not. I also got the regular one and am now contemplating getting the 2-way advanced.I just ordered the remote start for my Malibu on Monday, and the dealer called to say it's in. When I called to order it they offered me 2 kinds, the one that comes like it does from the factory, or a 2 way one. I just got the regular one.
Check out the GM Accessories website.
http://www.gmaccessorieszone.com/Chevrolet/2010/Malibu/Remote%20Start/?tx_gmshopb2b_pi1[type]=gm
The 2 way seems cool, but also seems like overkill at the same time. I wonder what kind of battery the remote uses and how long it lasts. I know my cousin had an aftermarket one before that used AAA batteries and it needed a new set every month.Good for you, it is an nice feature to have. My Malibu was already equipped with it but my Silverado was not. I also got the regular one and am now contemplating getting the 2-way advanced.
Overkill maybe but I like the thought of having one fob for both my vehicles. That way I can carry both keys on me and only one fob that can be used on either vehicle. I'm always misplacing my set of keys and can be bothersome when I need them quickly.The 2 way seems cool, but also seems like overkill at the same time. I wonder what kind of battery the remote uses and how long it lasts. I know my cousin had an aftermarket one before that used AAA batteries and it needed a new set every month.
Can you program it to two vehicles??Overkill maybe but I like the thought of having one fob for both my vehicles. That way I can carry both keys on me and only one fob that can be used on either vehicle. I'm always misplacing my set of keys and can be bothersome when I need them quickly.
Yep, it says it on the info I found.I found this info on the 2-way fobs......
DESCRIPTION:
Introducing the innovative 2-Way Advanced Remote Start. Now available for select GM vehicles (see below for detailed vehicle application information). The 2-Way Advanced Remote Start allows customers to upgrade their factory keyless entry or factory remote start systems to provide enhanced functionality. In addition to extended range remote keyless entry*, extended range remote vehicle start, and standard functions like door lock/unlock, vehicle locator/panic alarm and power liftgate open/close (if vehicle is equipped), this new accessory also features technology that allows 2-way communication between the key fob transmitter and the vehicle.
The key fob transmitter provides immediate visual and audio confirmation that a key fob command (like start vehicle, lock/unlock doors, etc.) was received. The large, easy-to-read LCD screen displays status/data when within range of the vehicle such as Fuel Level, Tire Pressure, Odometer Reading (accurate within 1 mile), Clock/Remote Start Countdown Timer, and Key Fob Battery Life Indicator. Customers with vehicles equipped with steering wheel controls (UK3) can even scroll through their pre-set radio stations.**
* Up to three times as far as factory remote keyless entry
** excludes HHR and G6
EFFECTIVE DATE:
Immediately for all vehicles listed below except HHR. The 2-Way Advanced Remote Start for HHR will be available shortly.
QUALIFICATIONS:
Fits specific makes/models.
GENERAL INFORMATION:
Antenna location varies by vehicle make/model.
Key fob can be programmed to control a second vehicle if that vehicle is also equipped with 2-Way Advanced Remote Start.
If reprogrammed, factory key fobs remain operational (except HHR & G6; 2-Way Advanced Remote Start kits for these vehicles include one new factory-style key fob to replace the factory fob).
To preserve battery life of the 2-Way Advanced Remote Start key fob transmitter, the image on the screen remains illuminated for approximately 5 seconds. To recall image to the screen, simply press any button once. To illuminate backlighting, press one of the side buttons once.
Important Installation Information:
• Estimated installation time: 1.1 – 2.3 hours, depending on vehicle
• Installation instructions available via Service Information (SI) website
• Requires service programming and scan tool
• Adhesion promoters are not included in kits. Order GM part number 12378555 for glass surfaces on '08 HHR and all full-size SUVs, or
12378462 for all other surfaces on all other vehicles.
• G6 requires a small piece of felt/flocking tape which is not currently included in the kit. Call 1-800-654-6333 to order BSR part number KT13296.
GM Accessories permanently installed at the time of new-vehicle delivery are covered under the New-Vehicle Limited Warranty. If installed after delivery, coverage (parts and labor) is for the balance of the New-Vehicle Limited Warranty, but not less than 12 months or 12,000 miles (whichever comes first). GM Accessories not requiring installation or purchased over the counter carry a 12 month limited warranty (parts only).
This product is also covered under GM Protection Plan (GMPP) Major Guard and Smart Protection vehicle service contracts. Please refer to the current GMPP administrative guide for coverage details.
If you have additional questions, please contact your District Parts Manager (DPM) or Regional Division Marketing Manager-Accessories (RDMM-A).
