The passenger headlamp assy is broken. From the new headlight assy, appears to have only two connection points for the unit but I don't know how to get to those connection points to remove the broken unit and install the new unit. The existing descriptions are for 2008/09 vehicles which don't look close in resemblance. Any help on what needs to be removed to replace the assembly would be greatly appreciated.
Thanks in advance, Dave
There are only two connection points, which are known as "latches." All you do is pull up on the latches lightly, and remove the headlights. The new headlight should have a new low and high bulb. You simply disconnect the clip that holds the light bulb and wiring harness together for the low and high bulb. The turn signal bulb is a little different. There's a little tab that you press when you twist the turn signal bulb counterclockwise and pull it out. Take the new headlight and connect the low and high bulbs, but be careful not to switch up the wiring harness for the bulbs. Then you put the turn signal bulb back in and match up the latches and your done.
