My 2000 Malibu's plastic line between the purge valve/solenoid to the vapor canister snapped when I replaced the EGR valve a while back. Currently it's rigged to maybe function in the meantime, at least I think; hard to say when functional relies on nothing leaking. Regardless, to my surprise the hardline snapped when the ratchet I was using tapped it, must have been brittle from the age and heat. That worked for the meantime, but I really need to get around to repairing it.
No amount of gluing is going to fix it due the small but constant tension it would be under when hooked on to the valve/solenoid, and given that it's dealing with gas vapor, I'd prefer not to plastic weld it, if that's even possible given the kind of part it is. Sadly, looking online has yielded no results. I can find the valve/solenoid itself, but not a line for between it and the canister. It also has a very particular means of fitting onto the valve/solenoid so I don't think making something custom is even an option. Any help would be very much appreciated.
