Okay I have a 04 Malibu Maxx ls I've replaced the battery alternator and serpentine belt. This is my issue so I lose my power steering then my lights are flickering on the dash then I loose power to my gas pedal then my car kills. When I try to restart it it does nothing but click click click. But I have enough power to roll my windows up but noticed when I press the buttons the lights will go out on my dashboard. I'm so confused. Would a bad ground or loose wire do this I've checked fuses and replaced a couple relays as well
New battery can be defective. Take it back and let them load test it to rule that out first. Make sure battery cables are clean and tight also.
Reactions: campb292
