Hi I have been reading the forum trying to figure the surging problem out on my daughter's 2000 Malibu. It cruise's fine, but when setting and idle it runs rough then worsening when idle in gear. Though takes off and cruise's fine. I have ran my scanner and replaced the following laundry list.
EGR valve (though new code for EGR came back)
IAC
TPS
Upper and lower intake manifold gaskets
Injector orings
Plugs
Wires
Coil packs
O2 sensor
PCV
PCV tubing
Fuel pump
Probably forgetting others
Ran smoke to try and find a vacuum leak the only thing was the tube to the valve cover under the coil packs. Before I buy another EGR I figure I would ask. It's throwing codes for p0300 misfire
P1404, p0404, and p0131
I'm stumped
Thank u in advance
Adam
IAC
TPS
Injector orings
Plugs
Wires
Coil packs
O2 sensor
PCV
PCV tubing
Fuel pump
I'm stumped
Thank u in advance
Adam
