381 - 400 of 453 Posts
Either you have a different problem or your dealer is feeding you some baloney. The shift to park issue, where you shift to park, the P lights up but it says shift to park on the DIC, is corrected with a 0.8 hour labor process where they clean the shifter and install a harness and switch. The harness is $15. The switch is $28. I have the part numbers and prices I can link if needed. They don't even list the shifter replacement in the bulletin anymore as the switch is what malfunctions. Even if they just put in a completely new shifter the part is $150 and it takes 1.7 labor to replace (published labor time, non-warranty).
They haven't made this one a safety recall because the car is in Park as far as the transmission is concerned. It is the BCM that isn't getting the signal because of that switch. An argument can certainly be made since the ECM is the receiver of the primary signal and the BCM acts as a backup. If the backup is toast, you are hanging by a thread metaphorically. But with zero accidents are barely any complaints at the NHTSA beyond cost, years have gone by and nothing.
Thanks for the reply, I was this close to having a $1500 bill for no reason apparently. It sounds like they’re trying to take advantage of me with the situation, I would appreciate the link if you can but if not you still helped me way more than you know!
Here is the latest "shift to park" bulletin: https://static.nhtsa.gov/odi/tsbs/2020/MC-10186071-9999.pdf
In that bulletin, your Malibu would need two part numbers:
Harness: 84733196 GM list $12.75
Switch: 84955381 GM list $28.52
The bulletin has the in-warranty labor time listed. The out of warranty time can be higher as that bulletin labor time just reflects what GM says the operation should take.
If the bulletin fix fails, or you went to an independent shop for replacement, the shifter is part 13534322 (previously 13520828) listing at $150.09
Those parts/prices can be found here which shows the sale price and GM parts catalog list price (you usually pay list price at the dealer): Select Parts Category - 2017 Chevrolet Malibu | GMPartsDirect.com
Reactions: n33mb
I just called the Chevy dealership and brought this up and asked how they got a $900 estimate for parts and they were at a loss for words, said something like “uhh.. I don’t know we do things differently here, but our prices won’t change” so it’s pretty clear to me they were gonna completely screw me over. You definitely saved me here!
The problem also stopped randomly within the past week so if it happens again I’ll come back to this post for specifics and head to a different shop.
I don't like that, but, giving them the benefit of the doubt: GM has changed this bulletin 3 or 4 times. For a few years the bulletin just had them replace the shifter. They were charging 500-700 for that out of warranty. This latest bulletin revision just came out in December 2020 and is a different procedure. It is possible they do not know of the new procedure and are quoting (still high) based on outdated info because the tech didn't actually search bulletins just recalled from memory. That said, different shop is a good idea if it comes back.
Reactions: n33mb
2018 Malibu LT
I recently started having the shift to park problem on my 2018 Malibu LT (10,000 miles). It occurs randomly about once every 10 to 15 drive cycles. If I take it to the dealer for repair (under warranty) chances are they won’t be able to reproduce the problem themselves. So, will they take me for my word that my car has this problem? Does this set a diagnostic trouble code? If not, how can I prove that I am having this problem? I guess I could take a picture of the message on the DIC the next time it occurs. I don’t know if this would be proof for them.
I plan to take a copy of the latest TSB when I go.
The STP behavior has changed on my '16 Malibu LT in the past month. I got the original wiring harness fix 18 months ago for $75 on the OEM shifter assembly. Over time the message gradually diminished except for shutting off the engine from a cold start after driving 1 mile or less. Now the STP message is displayed about 60% of the time after I shut off the engine, regardless of how long it's been running after a cold or warm start.
However, the harness is doing its electronic thing because the STP message always disappears on its own 5-30 seconds after engine shutoff. Not sure if this is a permanent change in STP behavior or if the harness will eventually not stop the message from going away on its own...time will tell.
2018 Malibu LT
Well, now my '18 Malibu LT is giving me the "Shift to Park:" message 4 out of 5 trips. I have scheduled an appointment with my dealer for tomorrow. I will post the result of that appointment.
Update: Not using the parking brake has almost eliminated the STP message...and when it does happen, it still goes off on its own within 30 seconds. In the past, using the parking brake stopped the STP message, now not using it does. Go figure.
2017 Malibu lt
I realize there are 300+ posts spanning over 4 yrs. Just would like to see if I could summarize for those new to problem like me? Located next to shifter assembly is a sensor/switch on the end of a conductive v-spring that makes contact w/ metal part of shifter? This tells the car its in park. Over time spring force weakens or contact surface gets dirty, and connection gets weak? Gm denied issue for a couple yrs, dealerships can't reproduce, doesn't exist. People took videos/pictures of shift to park message while clearly in park. TSB issued to replace shifter assembly, worked for some not most? $600+ if your out of warranty, would rather remove console & stretch spring. Most recent TSB replace wire harness/switch, clean contact surface? $40 parts, .80 hrs labor? My last oil change took 1.5 hours! Did I miss anything? Will continue to get worse, no amount of pushing forward/jiggling shifter helps.
Some generalities are a bit off but pretty close. Most of that is in post 2 as indicated in the discussion title. How is your repair going?
2017 Malibu lt
Only started occurring 2 weeks ago and just happened for 3rd time getting home from work tonight. Was able to push shifter forward harder and make message go away. Haven't been to dealership yet, wanted to do my research first.
2017 Malibu lt
Update, if anyone is interested? Had to "discuss" with service advisor doing TSB repair vs. diagnosing problem first. 36/3 warranty expired, im paying, just fix it. Of course since appointment was made has not occurred since. Have gotten into habit of "nudging" shifter forwards 3x b4 turning off? Today. 2.25 hrs wait! $16.58 for harness, $ 34.22 for switch and 129.88 labor. Invoice mention R&R shifter, cleaning? Replaced BTSI? Time will tell.
I have this problem with my Chevey Hybrid 2017. I just got home from the beach after being stuck with the car not starting, the steering wheel frozen and the SHIFT TO PARK message. I had AAA coming but I kept on trying to work it. I started squeezing the buttons on the shifter, pushing it further into park mode, wiggling the steering wheel, and keeping my foot on the brake. ONE OF THOSE THINGS WORKED. From another video I watch, I believe it was the squeezing of the shifter buttons that finally did the trick.
It is infuriating to hear that dealers are telling most of you that they have to observe it to fix it. Even the guy who videotaped it was turned away with "We still have to see it to know what it is." THEY KNOW EXACTLY WHAT THIS COMMON PROBLEM IS! This is just the dealership cheating you all. Here's video on an easy fix rather than replace the entire shifter assembly: (view at 2:59 - 3:43)
70984
70985
Omeron microswitch tear down that cause shift to park error message in 9th generation Malibu and some other GM vehicles, the video shows that the microswitch built mechanism is too week for the application, GM should look for a more robust switch other than that.
My 2017 Malibu started displaying a message on my board telling me to shift into park after I have turned the vehicle off. When I exit my car with my key fob with me, it beeps 3 times and the dash lights remain on. My car only has 21,000 miles on it and I bought it brand new.
I noticed this has been an ongoing issue with Chevy Malibu's and from this forum over 3 years now. I do not understand why Chevrolet has not stepped up to fix this issue with its vehicles, instead passing the cost on to the consumer. Shame on you Chevrolet! Of course this issue only started a few weeks ago when the warranty just expired.
If I had known Chevrolet does not want to take the initiative to "make it right" for something they are well aware of that is happening, I would not have bought the Malibu. I own two Chevrolet trucks and now second guessing my next purchase. I may no longer want to be a Chevy driver. Anyone interested in purchasing a Chevy Malibu?
No way used car prices are through the roof! My 2016 is up about $3000 over the last year. Cars appreciating is unheard of but the supply situation is historic.
As for shift to park, GM deserves their feet held to the fire. There are a few threads on here, this one being the longest at 20 pages. They should have created a special coverage program covering it to 120k or 10 years. My gut tells me a program is still coming. They didn't want to start one because they hadn't fixed it yet then the chip shortage happened. The 20s and up have not had this problem. I'm on my 4th shifter and the most recent replacement was a part matching a 21.
Reactions: DrivenDaily
Hi, I have an appointment to have this issue fixed, but it's 3 days away....today I had a hard time trying to get error to shut off....I do so by restarting the car, shift the shifter a bit and then shut car off...well....it took 3 times to do this in the morning and tonight it took about 8 times..ugh! Does anyone have a simpler or better way to shut off the error until I can get it to shop? I feel restarting it over and over can't be good
