Are you sure you are getting the right part number? In your other thread you were dealing with a 400A fuse. Now a 350? I see some conflicting info online and need to check my own malibu to see. I will later today.
The starter is the only thing it links to. The way I read the first post it blew then the OP changed the alternator, battery, fuse block a bunch of times then the starter. I totally agree on using a new OE starter though. I searched this forum and found lots of posts in gen8 but not much in gen9 - only one other post and it was a guy helping someone else.Is that fuse protecting the starter? If so what brand of starter was installed? Reman or new? I could see a reman. starter being defective as most reman parts are very questionable.
