I have a 09 Chevy Malibu 2lt 3.6l vvt v6 and everyday when i start my car there’s a thick white cloud of smoke that just shoots out my exhaust. After like 5-10 secs it stops and it stalls just a little bit at first but when I drive fir a few mins it runs and dives perfectly. I’ve checked coolant and oil. Have no idea what it could be. No weird color in the oil. Maybe a little dark but I probably just need a oil change. But no leakage or anything that I can physically see. I just don’t wanna go to a shop and have something big and expensive be done when it could’ve been cheaply done at home. Anything would help just in a tight money situation and can’t quiet afford an expensive fix. There’s also this picture some line and it seems to have a slight leak but don’t know what it is.
Sleeve Grey Automotive exhaust Motor vehicle Silver
Vehicle Car Motor vehicle Hood Automotive design
That aluminum line with the rubber over it is the AC line, or rather one of them.
If you'd like better performance from your engine, move that air filter out of the hot engine bay to inside the fender where the original air box got its air. Either that or put the original air box back.
Of course, if you have recently "cleaned" that filter and then oiled it, there could be too much oil on it that is getting into the air intake.
It could also be completely not associated with the air filter but be from the PCV hose that is getting too much oil vapor. I've had a small amount of liquid oil inside the opening of my intake (past the TB) before, so it's not impossible that your engine could be pushing more oil into the intake than usual.
My 3.6L is a 2011 model, so except for maybe the reluctor wheel that changed at some point, they should be just about identical engines.
How many miles are on your engine?
145,000
