I've had two of these already, the tire pressure monitor valve stem assembly was leaking air. One leaked so fast that I didn't even have time to pull over and change it before it went flat. Now I have a third tire that is running low on pressure every day. I fill it in the morning, it's low by end of the day, it's down to less than 20 psi by next morning. I think it's the same issue. Anyone else seen this? I'm running 34psi with it being around 20 degrees F out there. But the car sits in a garage.
The dealer "tightened" the first two on two separate occasions. Haven't had a problem since. This feels like the first two. I'm just a little tired of this problem.
