If yours has the label on the driver's door pillar, it'll tell you what sizes are available as stock options. Using a tire that is smaller in diameter will cause you to be driving slower than your speedometer registers. But the bigger problem is that the sidewall is smaller, which means you'll experience even more of the bumps in the road than with the taller sidewalls. Your mileage may also be negatively affected.
