This is quite challenging…., the TPMS Sensors on my car are working “fine”, however I sense that the setup point on which the sensors triggers the light indicator on the dashboard its set-up too low, meaning that it won’t go on until the tire has less than 12PSI, this cost me already 2 tires by keep driving them with such a low pressure.
It would be nice if the light indicator on the dashboard goes on when a tire loss 20% of the recommended air pressure or a tire gets below 25PSI, can this be modifed?
What is the factory setup point?
Haven’t modified anything around that since new, still running on the OEM rims and keep buying the same recommended brand/model tires on every change.
By the way I Own a 2008 Chevy Malibu.
