I bought my 2014 malibu 1lt with 57k miles it now has 72k miles gm says to change the transmission fluid every 45k miles? Would it be a good idea to jack the car up unbolt the tranny plug drain what fluid comes out and change the filter ? I’m not sure if the previous owner even changed it at the 45k mark.
It would be good to change it.
When buying a used car, there are those who recommend changing all of the fluids in the car just so you'll have a baseline from which to operate.
Ok I was thinking the same thing I was just a lil precaution on changing it and something happening, I probably shouldn’t flush it ? I should just drain whatever comes out and fill it with the exact that came out
Yes, you should do exactly that (drain and fill) and you should be fine.
On my 2012 Malibu it says the trans. filter is internal and not easily accessible. Not for a do it yourselfer.
The "filter" is just a screen that is trapped between the two case halves. It can be serviced only when disassembling the transmission.
Just do a drain and fill. Most of the time, it is recommended to follow the owner's manual, but it says not to worry about the trans fluid for a long, long time. Change it every 50K, or every 30K if you do a lot of city driving. Or ask a trusted mechanic who knows how to properly treat a lady, er, car. ;)
