1 - 20 of 347 Posts
CMF Senior Member
TRIFECTA presents: Chevrolet Malibu Turbo MY2013+ Powertrain Calibration Reprogramming
TRIFECTA presents a complete powertrain power delivery profile recalibration for the MY2013--2015 Chevrolet Malibu Turbo 2.0T LTG engine and corresponding 6T70 automatic transmission reprogramming. The TRIFECTA Performance Chevrolet Malibu Turbo 2.0T MY2013--2015 powertrain calibration is an easy to install software performance recalibration with an included flash loader device that will yield specific power increases of +83 ft-lbs and +62 WHP (Peak vs peak gains of +38 ft-lbs and +66 WHP) to a completely stock Chevrolet Malibu Turbo 2.0T MY2014.
View this product in our Store!
^ Image links to WOT-Tuning.com since we cannot embed the video here.
The TRIFECTA Advantage Powertrain Recalibration for the MY2013--2015 Chevrolet Malibu Turbo includes a TRIFECTA flash loader.
Specifications of the TRIFECTA Performance Chevrolet Malibu MY2013--2015 2.0T LTG ECM software reprogramming:
-Specific power increases of +83 ft-lbs and +62 WHP under the curve (Peak vs Peak gains of +38 ft-lbs and +66 WHP on 91 octane)
-Powertrain calibration has been tested and validated for various environments, such as cold/heat, elevation, and variations in fuel quality
-Extended testing of more than 100,000 miles with 100 hrs + of wide open throttle testing
-Power feels linear and immediately responsive
-Retains all GM OE diagnostics and ECM functionality
-Retains all OE error code reporting and functionality
-Emissions readiness checks are present; emissions compliant
-Maintains functionality of ABS and TC systems
-Knock detection mechanisms and OE engine knock detection sensitivity is retained
-With the current generation of TRIFECTA's flash loader solutions and the TRIFECTA Transparency featureset, when flashing your vehicle, the TRIFECTA flash loader does not increment the ECM write counter or increment entries in the flash history
-Return to stock functionality included with flash loader
Specifications of the TRIFECTA Performance MY2013--2015 Chevrolet Malibu Turbo 6T70 6-Speed automatic transmission TCM calibration software reprogramming:
-Supplementary 6T70 transmission TCM reprogramming compliments the ECM reprogramming and completes the TRIFECTA Powertrain Calibration: designed to work in unison with the ECM reprogramming for optimized performance
-Improved shift times in adverse shift patterns
-Improved shift logic
-Does not shorten transmission life or increase cooling requirements
-Retains all OE diagnostics and TCM functionality
-Improved fuel economy with improvements made to torque converter slip profiles
Installation Notes:
-Estimated installation time of ~20 minutes
-Premium fuel is recommended, but not required
Additional information and availability:
-This powertrain calibration includes a TRIFECTA powertrain calibration file specific to your vehicle and includes a flash loader device
-Powertrain calibrations currently exist for the US, CA, EU, and Asia areas, with more regions to follow
-The TRIFECTA Advantage Calibration is designed for a 100% stock vehicle. Any aftermarket hardware designed to work on a stock vehicle may work without issue, but there is no official support for it with this calibration.
So those numbers while they do sound impressive, leave me with some concern. This mod is talking about a grand total of 325HP and 333FPTQ. is it just me or does that seem like ALOT of power being pushed out of a 2.0L four cylinder?? Just wondering what this is gonna do to the engine and transmission on my $35,000 car Ya know?
let's be honest here I'm going to pull the trigger on this regardless. I trifecta tuned a sonic turbo and that thing turned into a quick little car. but alittle reassurance would be nice. I'm worried about the auto transmission handling this.
Same concern I have as well.
The power isn't an issue for the engine. GM used to offer a warranty-retaining stage kit that brought the 1st gen 2.0T over 300 hp and 330 lb-ft. If there's any weak spot, it's the transmission, because the 6T70 is rated 315 hp and 280 lb-ft of torque. From what I read, they adjusted the torque of the new engine to 295 lb-ft (up from 260) after further testing.
Vince of trifecta, who wrote the Malibu tune, owns the Malibu that was used as a guinea pig. I heard his car has a more aggressive tune than they sell, and he is convinced the tune is completely safe.
Take that information and make your own conclusions.
CMF Senior Member
Discussion Starter #9
Correct. GM just released a Stage kit for the LHU Regal (2nd GEN Ecotec Turbo) that raises HP and TQ to roughly 300/335. So, these engines can handle it. Another thing to consider is the way in which we develop and deliver the power. It keeps things safe. Its not a balls-to-the-wall tune. It was developed to mild mannered and safe while still providing the extra fun-factor.
One last thing, remember that you aren't ALWAYS making all that power. The engine basically drives around with stock or less than stock power for everyday driving. Its not until you get on it at WOT that you will be making all that power from the engine :)
LHU is the first gen 2.0T (it was used in Regals built prior to 2014). That's a derivative of the stage kit they used to offer on the Cobalt SS and Pontiac Solstice GXP. It's not compatible with the new engine.
I want to pull the trigger on this myself. By Mid-June or early July I should have some play money to purchase this. My Vegas trip later next month will require some monetary recovery time.............lol
Vegas will do that to ya...
Maybe some better transmission fluid would help it? I'm trying to think of things to do to help alleviate some of the added stress the extra power is going to put on the transmission, besides keeping my foot off of it which we all know is not gonna happen.
My tires are 6/12 tread after 19,000 KMs :(:(:(:(:(
Just purchased a 2013 and am very interested. My only concern is if I throw a check engine light or have any issues will the dealership be able to see the ECU has been tuned even after I restore it back to factory settings with the flash cable? Would hate to void my extended warranty of a car I haven't made my first payment on.
Traded my 2014 2LT RS manual on it. Previous car was a E39 540i with 293hp 320lbs and would love that power back without the 13mpg!
Ouch, we touch the 30's (F) a handful of times a year and might see "snow" once every 5 or 6 years or so.
But Im not a fan of the cold at all, grew up in NYC and I'm permanently scared. It's definitely worth the 5% tint to battle the 6-8 months of 90°+ and 100% humidity.
1 - 20 of 347 Posts
