I had my 09 in for service, to replace the thin pressboard panel that covers the spare. The bolt that holds the spare sticks up to support thr center of the board. When I carried something heavy, the bolt punctured the board and carpet. I went to the dealer, They thought that it might be considered a wear item and therefore not covered. They changed it as warped. The suggestion was to add a 2 X 4 as a spacer. I went all out and used a 2 X 6. I hope this is not a problem with other parts since I figgure that next time I might get "do you own a roll of duct tape" I should not have to make parts to fix my "new" car. I talked to Chevy, and they said that they will make a note of the problem. I felt blowen off.
