Turn signal issue
164 Views 1 Reply 2 Participants Last post by  campb292
hi everybody
I have malibu 2018 L model.
the turn signal start to behave abnormaly and continuously as below :
  • when arm lifted up ( right signal ) it works.
  • when placed in mid position (off) still the right lamp flashing
  • when place down for the left signal, the right flash stops but left one not going to flash.
any advice?
regards all.
Sometimes there is corrosion inside the switch that can be cleaned. It depends on the design and if they made it easy to disassemble. You could try removing it and cleaning if it is hard to obtain the replacement part in your location. The replacement part is # 84925178 if needed.
