I am currently trying to fix a friend's 01 Malibu. For some reason, the turn signals and hazard lights have been acting up. Some times, they will work just fine. Other times, they will work for a couple seconds and just go out. Then sometimes they wont come on at all. Anybody else come across this problem????
Yes, and it's with the Hazzard switch on the dash, which is also the turn signal flasher. GM had a TSB on this issue and it covered several years of the Malibu, it's only about a $20.00 part and is easy enough to replace by popping off the trim piece the Hazzard switch is in and popping the switch out from the back and unplugging the old one to plug in the new and reinstall.
I replaced mine on my own, after I found out about this issue, it wasn't worth bothering the dealer since I bought the car used.
