1 - 8 of 8 Posts
Hello everyone. Great site very informative. I had a question I hope someone can help me with. I just purchased my mother-in-law's '05 Malibu LT V6 with only 31 km on it (19,000 miles). I have two small children and was concerned about the Ultra Lux material the seats are made from. Can I Scotchgaurd this fabric or will it get ruined?
Thanks
I don't know much about the UltraLux seats (even though I have them).. assuming they're the same as the 2008-2009 ones, I have read about other people Scotch-guarding the seats. You may want to wait on another response to verify this though.
Thanks
There is a similar thread I found: http://www.chevymalibuforum.com/forums/showthread.php?p=11510
You could probably use some protectant you find at a shoe store for suede shoes, but I'd be very conservative in applying it. I wouldn't use any cleaning chemical though, and personally I wouldn't use the protectant either. You can also pick up a suede cleaning tool (basically an eraser) which works really well at cleaning it up, making it look new and fluffing it out a bit, but you need to be gentel with it, and a lint brush may work better for this application and material.
It isn't real suede though, so you really don't need to seal or protect it. There is a link in the other thread to care for ultrasuede (basically what this is) so check this out too:
http://www.ultrasuede.com/about/care.html
As a synopsis of that page I'll say that general upkeep is about brushing the fabric with a lint brush, and occasionally vacuum it. You can clean most stains by gently cleaning with a damp towel. For oil bases stains you would dampen the towel with ethyl alcohol.
I used to do lint brush but found vacuuming is much more effective and faster. The ultra lux looks great after it gets vacuumed. If you have a vacuum with long hose like mine, vacuuming is not harder and should take you several minutes to do all the seats.
Don't bother to put anything on it. I did try one product used for leather coat but did not see anything different. It actually can make thing worse
If I'm right the only thing you can do is use a damp cloth to clean up spots on this material, anything else will ruin it. I thought this material was supposed to be less subject to staining.
I Agree, a damp cloth, some warm water, and a good vacuum is all I would use.
1 - 8 of 8 Posts
