Re: oil visible in turbo
Many possibilities. The turbo is internally lubricated and cooled with oil. If a seal is leaking, oil could become visible. Crankcase vapors are routed out of the crankcase through the camshaft cover and routed for combustion. Some vapors do cool and are captured in that separator. If that is full or some sneaks by, you could see it toward the end of the outlet duct and inlet to the turbo. I wouldn't immediately be concerned but there are some things to look over to gather more info:
1) if oil change is recent, like <500 miles, is the oil you see clean like new oil or gunky mess like you saw from the intake tube and catch box?
2) If you pop off the charge air outlet tube where it connects to the throttle body, do you see oil on the throttle plate? Tiny bit or a lot?
3) have you noticed oil consumption?
4) is the coolant in reservoir stable?
