when i start my car it starts fine until i shift into drive. when i shift into rev in rolls back fine.and when i put it in neutral it doesnt even roll forward. i did some research online and all i came across was the trans solenoid wont unlatch or the torque converter is bad. i pulled the fuse to the trans and my car worked fine. the only bad thing is that when i drive on the highway it doesnt shift so the rpm keep going higher. i need some serious help cause this is my only car
If it's under 3/36 then take it to the dealer or have it towed there. Call them if it's within 5/50 to see if you still have powertrain warranty. Let your warranty help you, if you still have it.
