Dont know about that.....maybe you got a batch of bad gas from either filling up while the truck was there or just after they left or the tank was just about empty ????whatever u do though, never run on 87 octane or lower as that will cause problems for your fuel filter and it will misfire, and drive like crap. Thats from my experience
The gains will be marginal. The only time I would use a higher octane is if it contained 10% ethanol and was cheaper than 87 w/out ethanol.Around here, higher octane gas has less ethanol, thus giving better gas mileage.
I have to disagree with you on the better mileage with non-ethanol gas. I use ethanol gas all the time and I get on average 35 MPG. Also the 4 banger runs just fine on ethanol.I run 87 octane. Never had an issue. I have the 4 cylinder with 35,000 miles. I do run non-ethanol gas though. Here in Oklahoma you can find ethanol and non-ethanol "Real gas" as most stations call it. The car does run much better on the non-ethanol "Real gas" and the mileage is better as well.
35 MPG?? At what speeds?I have to disagree with you on the better mileage with non-ethanol gas. I use ethanol gas all the time and I get on average 35 MPG. Also the 4 banger runs just fine on ethanol.
So you disagree that my car runs better on the non-ethanol gas? Have you been driving my car??? If so.....then you owe me gas money.I have to disagree with you on the better mileage with non-ethanol gas. I use ethanol gas all the time and I get on average 35 MPG. Also the 4 banger runs just fine on ethanol.
Well maybe I do....but not likely. After all we are only about 80 miles apart.So you disagree that my car runs better on the non-ethanol gas? Have you been driving my car??? If so.....then you owe me gas money.
If you're using 10% ethanol the car should run no different. If it does, then something else is wrong with your car. As far as gas mileage, it is true that you may get a little worse mileage, but if you do it's only about 1%. There are too many variables to make that a solid case though. One tank of regular you may get 31mpg, and onther w/ethanol you may get 33. Different driving conditions are going to affect the mileage more than running an ethanol blend.So you disagree that my car runs better on the non-ethanol gas? Have you been driving my car??? If so.....then you owe me gas money.
10% ethanol gas has 92% of the energy (BTUs) of 100% gasI have to disagree with you on the better mileage with non-ethanol gas. I use ethanol gas all the time and I get on average 35 MPG. Also the 4 banger runs just fine on ethanol.
