97-07 owners:
My ‘07 Malibu has a moisture problem. The windshield and rear window keep fogging up unless I keep the defroster on. I’ve also noticed that when it’s been raining, the windows will sometimes fog over. Is this common for these cars, or do I have a leak somewhere?
You have a leak.
Check the AC condensate drain, and if you have a sunroof, check its 4 drains as well.
Check the door seals, trunk seal, and where the outer body side meets the top of the roof. If there's a channel, there could be a leak there.
Check the windshield and the cowl air intake.
Use a hose and start from the bottom up, moving slowly, with someone inside looking and listening. (So that means nobody who needs to be on their phone constantly or jamming to some tunes.)
