The other day threw these codes. The car wouldn't come out of first gear, limped it home and sat all night. Woke up and test drove did fine, shifted through all the gears and reverse (whew) Code P0717 is the Turbine shaft speed (TSS) sensor, now is this the 3-5 wave plate issue or just the sensor/wiring. Trying to locate it to replace and cant find a solid diagram of the location any help would be greatly appreciated!! and thank you for any help!
