21 - 31 of 31 Posts
Do not use universal fluids period. Use only a dedicated Dexron VI fluid only. Dex VI may have a Ford LV approval also on the bottle but that's OK as some Fords use Dex VI.
Meets and is are two different things.
Reactions: campb292
Save
Just curious if you've seen failures on the 9T50 or 6T40 where "suitable for use" fluids were used.
I've been using maxlife or the above mentioned Castrol Transmax for years in various domestic and import ATs and CVTs for years without issue.
If I was paying a shop to do the job, I would expect them to use OEM fluids.
Save
+1
I have no idea what leads an owner to say no to a trans fluid manufacturer's certified/licensed fluid and opt for the "it's pretty good and works in a cvt, lawnmower, or your wok for a stir fry" alternative.
Save
Lots of problem reports on this forum after using non-dex6 fluid in the 6T40 or other 6-speed on this forum. I haven't read any reports on the 9T50 as I haven't read of many owners even changing the fluid not to mention subbing an alternative to dex6. I quickly searched and found a perfect example... working fine before then immediately had problems after filling with maxlife universal "suitable" fluid. Once the junk fluid was removed and proper fluid installed it immediately worked like new: Grinding Noise After Transmission Fluid Change
Save
My daughter has put about 500 miles on my 2016 8th gen after I've run 2 gallons of Castrol Transmax though it. I'll see how it goes.
To me a lot of ATF problem posts are from people trying to fix an existing transmission problem with a fluid change. Most of the time it's not going to work.
Save
Only factory approved fluids in transmissions. One example of a different fluid is in GM 8 speed trans. in Camaro's and trucks. Torque convertor shudder appears in some units. GM instructed dealers to replace fluid in them with M1 LV HP blue label fluid. It stopped the shudder. I seems regular Dex VI is hydroscopic and was causing a shudder when convertor locked and unlocked. It is Dexron approved for use in high performance transmissions hence the HP designation.
I just did a fluid change in my '20 Traverse 9 speed with it since it's a more robust Dexron fluid that is OEM in Corvettes.
Save
Now you know why the severe schedule says every 45k miles.
Save
Everyone's experiences and opinions are going to vary. That said, I did another drain/fill with "suitable for Dex VI use" Castrol Transmax Universal ATF yesterday. ~15 quarts total run through this 6T40 from ~81K to ~83K miles. The fluid is getting cleaner. The transmission itself has not had any issues, just very dark ATF when we bought it last month with 81K miles on it. Still performing and acting as it should.
Save
21 - 31 of 31 Posts
