I have an 09 Malibu with 145K miles. I change the oil about every 6.5K with full synthetic oil.
I started noticing an oil drip under the left side of the engine by the bell housing. In researching this I seen many threads on the 2.4L Equinox having the problem. Its stated rather than putting in a pcv valve, GM put a very small 3/32" hole in the upper center of the intake that gets plugged over time. The result folks have posted is the pressure inside the crankcase builds and pushes out the rear main seal causing the oil drip by the bell housing.
I have not seen this issue posted with the GEN 7 malibu. Is this a problem. How can this be verified without removing the intake or even worse removing the transaxle and flywheel?
