Hello, recently picked up a 2014 LT with 2LT accessory package. I noticed when flooring the gas the car will hesitate or stutter before the RPMs go up. 116k miles on the car and no CEL codes. I can manually go through all the gears in manual drive mode and no issues
I am going to replace the spark plugs and coil packs this weekend but wanted to see if this was normal? Will also use some chevron Techron when I fill up next to see if it’s a fuel issue.
Let’s just say I haven’t driven an automatic transmission in awhile so I may be paranoid. Car seems to drive fine otherwise.
Engine oil , trans oil, coolant, brake fluid all recently serviced.
