2018 Chevy Terminal Replacement
2 reading
8.8K views 2 replies 2 participants last post by  Angel745
Is your 2018 still covered under B2B warranty?
If all that's broken is the terminal at the battery itself, I'd think it would be easier to just cut the terminal off and replace it. Yours may have some kind of fuse (or fuses) on the clamp itself. If so, look around at aftermarket audio places for special terminals.
Otherwise, a little PB Blaster or Kroil might work to help loosen the nuts you're trying to remove.
