2013 Malibu ECO - AGM battery or not
11K views 10 replies 4 participants last post by  pascal_poirier
#1 ·
Hi,
When I do battery searches for my 2013 Malibu ECO, I get results for both AGM and non AGM batteries. Is an AGM battery required for this car?
#2 ·
prolly not, depending on your weather get the same CCA or better if needed. it was noted that those living in very hot areas may benefit from a battery you can add water as no matter the battery type you loose a bit of water-electrolyte over time + sealed batteries are NOT exempt. battery prices like most everything else have gone nuts + searching will show ALL batteries are made by a few manufacturers although specs may vary
#3 ·
Generally speaking, Chevy put AGM in their vehicles with the stop/start feature and SLA in those without.
#5 ·
stop start will work with ANY type of good battery. AGM technology is said to endure deeper discharges than other battery types. stop-start is best disabled as its hard on the battery as well as the starter. from reading stop-start will be disabled if your battery reaches a predetermined charge level. as i noted with others using a smart charger is a good thing unless you drive long trips regularly. when a battery gets discharged + stays that way sulfation starts + that slowly kills a battery. check out batteryuniversity.com for a LOT of info on all types of batteries
#6 ·
Hi,
Car will run with regular battery but will likely die much much faster. The stop start system requires heavy duty batteries (e.g. AGM) and using a lower end battery may leave you stranded when the battery decides to die.
Sent from my LG-H873 using Tapatalk
#8 ·
what exactly does the computer do IF it detects sulfication? reading about battery charging says an unsealed battery can use special charging process to help selfication but notes NOT on a sealed battery as higher current used will evaporate fluids which is sure death if you can't top off the fluid level. i am all ears-eyes + like to learn new things as technology progresses or regresses!!!
#9 ·
#11 ·
The smarter charger in this case helps improve fuel efficiency and improves battery life. The old method would constantly slightly over charge the batteries which wasn't serious but not great.
Also the new systems have smart battery protectors which despite grand kids turning on an inside light during the day and me not noticing till the next day I didn't require a boost as the battery protection kicked in. The battery also charged back up to a safer voltage faster as it can charge at a higher voltage when the battery is drained without worrying that we are overcharging.
Yes complexity for complexities sake isn't good but some might say why complicate paper and mail as that works.... But then we wouldn't be having this discussion.
